SS-V: 6030 Simply Supported Thin Square Plate - Frequency Response
Test No. VD04 View frequency response of a simply supported square plate.
Definition
- Excitation frequency.
Sixteen (16) modes are used to approximate dynamics solution and 2% modal damping is assumed in all modes.
- Properties
- Value
- Modulus of Elasticity
- 2.e+11 Pa
- Poisson's Ratio
- 0.3
- Density
- 8.e+3 kg/m3
Results
Deflection Y Amplitude, mm | Surface Stress Amplitude, MPa | |
45.68 | 32.52 | SimSolid, 3D solid model |
45.42 | 35.08 | Reference, thin plate model |
